D16A1 VTEC upgrade
Discussion in 'HYBRID -> ED-EF / DA' started by klyph, Sep 9, 2006.
  1. klyph
    klyph Dismember VIP
    North Pole, AK
    Hey I have a D16A1 from an 89 integra. I was wondering if anyone knows what is involved in upgrading to a vtec head or if this is even possible. I've seen kits for ls/vtec upgrades and was wondering if something similar is possible for a D16A1.
  2. lil_red_rex
    lil_red_rex i do body work!
    west have ct
    sorry dude...this has been asked alot.....the d16a1 is like a motor of its own....d-series trannys will work with it and the exhaust manifolds....but the head and block are manufactured with differnt bolt patterns and coolant passages....so in easy words...no....cant be done....
  3. klyph
    klyph Dismember VIP
    North Pole, AK
    Yeah I kinda figured. Seems like they make lots of upgrade stuff for everything but what i have. :(
  4. Mr.Gerbil
    Mr.Gerbil Check your six
    actually the only transmissions that will work with it are the CG transmissions that come with the A1 and the 4wd wagovan transmission out of an 84-87 wagovan.
    Headers from single cams dont work without modification either and Vtec heads especially dont work.
  5. lil_red_rex
    west have ct
    are u fuckin serious.....headers from a single cam wont fit? why not they are d-series kid!!!! when u do a dohc swap into a crx or civic and u use sohc headers how do they not fit....u espicially cant tell ME they wont fit for the reason that i used them onmy swap this weeked...:owned:
  6. Mr.Gerbil
    So how did you make up for the bend that goes into the oil pan? Did you grind out the ports on the manifold? They dont line up properly with the DOHC heads. If you put the DOHC gasket up to the SOHC manifold its slightly off.
    Ive tried this before and it didnt work without extensive modification to the whole thing. The D16a1 is a whole different breed of d series and most new stuff will not work with them. Trust me, i own two of these older d series and a few newer SOHC motors.
  7. lil_red_rex
    west have ct
    u want pics asshole?
  8. klyph
    klyph Dismember VIP
    North Pole, AK
    Ya, whoah guys. Just askin a simple question. No need to threadjack it into a pissing contest. Jeez.
  9. Mr.Gerbil
    Notice his age.
    Thank you. Im done.
  10. lil_red_rex
    west have ct
    my age has nothing to do with it....and im not a noob to shit....ive been swapping shit since 10 years old i know my shit and to prove ur dum ass wrong here is a pic of a d-series header on a dohc d16
  11. Mr.Gerbil
    Thats a newer DOHC ZC motor, at least the head is anyways since the valve cover bolts are on the outside. I dont know if you can swap the newer DOHC heads for the old ones but i dont know why you would. Looks to me like you used the down pipe from the old DOHC manifold, but the top could be SOHC and if it is, your ports arent lined up properly. Im talking about D16A1s here. Not newer ZC's.
    What i used was a SOHC ZC manfold (the whole thing) which was 4-2-1 and it didnt work since the bend at the bottom was too much of an angle, so it bent up into the oil pan. Btw, whats with the hostility? My remark about your age is that your acting just like a 16 year old. Also, could you please point out where i said they dont fit? I said they dont work properly without modification. Thank you.
  12. 1gcvcb18
    1gcvcb18 New Member
    Not even the y8 head or b series fits?
  13. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the SOHC exhaust manifold/header will bolt right up, however the ports do not align - not a big deal - you can either grind out the header to match the head or just leave it - we have run them both ways and it doesn't seem to make a whole lot of difference either way - maybe a slight increase in power with it port matched, but you will never notice it in just driving it - here is a picture of the D16A1/DOHC ZC exhaust gasket on the SOHC header showing the amount of mismatch
  14. lil_red_rex
    west have ct
    yes it is as a matter of fact
