crxnonvtec
I keep going through the list but everyone keeps giving up on me ...or just reading the topic and and asking about stuff that was already in the posts..I cant seem to get the injectors to fire more then once all at the same time, and all the wiring to the injectors is correct..
Its a D16a6 basicly stock now besides exhaust, fuel pump is good, 35lbs to the rail, all the injectors are firing but only once, no codes, brand new distributor not a reman.,tried 3 different ecu's, the timing is dead on, both injector resistor boxes I got tested good, both main relays I have tested good also, Ive gone through the dpfi to mpfi wiring like ten times everything goes to the pins theyre supposed to on the ecu.
( I know people like to rip posts apart so when I say "both" I dont mean I have two on the car it means I have spares and duplicates of almost all my parts)
