well on mine, we have the timing kinda messed up, but basically everything's at top dead center. when my buddy put on the timing belt, he had it a tooth off on the crank end, so we had to compensate by having the adjustable cam gear advanced 9 degrees which equals out to 1 tooth. i wanna fix that so it's correct and so it doesn't look like i'm actually advanced that far lol. my stuff needs to be tuned badly. make sure everything's top dead center and go from there. make sure you use a timing light once you've checked that and dial your timing in. that should be one of the first things you do. what else is giving you an issue? just the timing? i mean, what's the problem?
