philyphreak2127
Back in the Game
Hey guys I have finally decided that I wanna go with a n/a setup my question for you guys is what pistons would be good for this setup? Anything higher than a 10:1 compression would be nice. I already went with arp head studs, and a brand new oem head gasket, a shitty ebay header, and a cai. Basically I am trying to see how far I can go hp wise with a n/a y8. I have seen may too many turbo d's and wanna go a different way. Not that n/a d-series haven't been done before. I plan on replacing the header with a dc sport header, high flow cat, and full 2.5 inch exhaust, and going with a obd-1 conversion and a p28 ecu. The block will be bored at least .30 over. Any suggestions on how I can push the most power from this block would be awesome!! I hear skunk2 intake manifolds are the best for an all motor setup, so I will probably go with that and a 65 mm throttle body.
