d16z6 in a 99ex problem
Discussion in 'General Tech and Maintenance' started by K20A, Nov 12, 2012.
  1. K20A
    K20A New Member
    i recently swaped a z6 into my 99ex, got the car to idle and it stratrt right up, used my 99 ex harness and ecu, swaped my y8 manifold and dizzy to the z6, car hesitates and its lag until 4500 rpm and when i give it gas it smokes light blue sometimes white. what can it be?i need help thanx
  2. K20A
    K20A New Member
    someone help me
  3. K20A
    K20A New Member
    someone help me with this issue please
  4. awptickes
    MD
    You're using the wrong ECU.
    Or your engine needs piston rings, valves, and the cams looked at.
  5. 916em1
    916em1 New Member
    Sounds like something wrong with your motor. Also the 99 manifold will have a big ass vacuum leak on that head There's a way to fix it ill post a link once i find it.
  6. 916em1
    916em1 New Member
  7. 916em1
    916em1 New Member
    But instead of welding the holes i got some allen head screws At a hardware Store to plug them off.
