can you tell the the exact models for the Dizzy, Engine and ECU?
ill ask some friends of mine
If the timing and wiring are correct it could be the reman. distributor or the chip. In that case, I lean towards the chip unless you got a bargain basement reman. distributor. If that's the case, exchange for another if possible. If that doesn't solve your problem see if you can get someone here or at PGMFI.org to burn you a stock Z6 .bin. People will usually do it for cost and shipping and if not it'll be around $20.
Did you have any material taken off of the headgasket mating surfaces? It still sounds like your cam timing is off.
Correct. But, when your timing's correct you shouldn't need to put the distributor all the way in either direction. Rent a timing light and find out where your timing actually is.
That sucks. At least Sunday's only a few days away.
Have you put the Z6 pulley on yet to see if that makes a difference? I think I remember you saying that.
I know that with my Z6, I timed it by ear and was way off when I put the light on it.
