DA lsvtec help!!!
Discussion in 'HYBRID -> ED-EF / DA' started by SupermanDA, Jul 10, 2012.
  1. SupermanDA
    SupermanDA New Member
    Ok so im new to all this, I blew my head gasket on my DA ls. So since im taking my head off any way i went on getting a gsr head but my problem is my intake mani wont bolt up to the gsr head. do i get a gsr mani? and if i do how will the vaccums work on the gsr mani to the car now? need help please!!!
  2. burninriceinva
    burninriceinva New Member
    Hampton Roads, VA
    There are a few aftermarket manifolds out there for this type of swap. Skunk2 Pro Black Series Intake Manifold GSR - JHPUSA IMO I would not buy a stock GSR intake setup go after market. You should be able to figure out the vacuum hoses without much effort. With a manifold like this should be pretty plug and play. At least it was when I put a GSR head on my B16. May have to extend a hose or two but nothing major. You will also need a Vtec ecu and wiring. Good luck on you project.
  3. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    There is a little more to it then just putting a gsr head on a ls block. Head has to be tapped for the oil port and so on. U will need a golden eagle ls vtec kit. Pretty much explains how to do it and comes with most if not all things needed. And u have to use a gsr intake mani. Aftermarket. Or stock. Whichever u can afford.
  4. FLounder
    FLounder power hungry VIP
    north palm beach, FL
  5. BaDarkus91lsvtec
    BaDarkus91lsvtec New Member
    palmton, ca
    U won't want to rev very high either cuz the stock rod bolts on the LS rods r weak and cannot take the high rpms of the gsr capabilities. That's why a lot of ppl blow their motor. I've had 2 friends think they could get away with it and both blew their motor in a couple weeks.
  6. AxeOfGlory
    AxeOfGlory New Member
    This is what I followed. The only thing I did different is i don't have anything after market besides Eagle H beam rods, and I guess ACL bearings. Wished i could have bumped up the cams, but didn't have the money haha
    How to build a "reliable" lsvtec/b20vtec - Honda-Tech
  7. SupermanDA
    Thanks guys and sorry it took me awhile to reply, I figured it out, just had to delete a few vaccum lines. I ended up getting a blox mani which made it a whole lot easier then the stock gsr. But now I ran to another problem, I got everything pretty much done put when I connected the p28 it has a engine code on, not sure why but only with the p28. If I run stock ecu there is no cel. What am i missing???? I drove it just to see if vtec works but it does'nt kick in. Do I have to chip the ecu for the engine light to be remove? Please help if you done this before thanks!
  8. dc4dude
    dc4dude Member
    chicago, il
    What the fuck is this shit???^^^^^
  9. BrutalB83
    Rochester Hills, MI
    Did you just plug in a stock P28? That should work great...for running a D16Z6. If you're running a modded LS/VTEC, then yes, you'll want to get it chipped for optimal performance...
    It's called spam. This is what spammers do, they sign up at forums, post a response to something that kind of, sort of makes them look like they're a contributing member, but then they throw in a link to whatever they're spamming...
  10. robby55
    robby55 New Member
    http://www.centplay.com/affiliate/id_130/
    You will need a golden eagle ls vtec kit
