DA trans
Discussion in 'HYBRID -> ED-EF / DA' started by schmuck, Oct 21, 2007.
  1. schmuck
    schmuck New Member
    Where can Ifind a cable trans for cheap and what do i need to do to make the swap
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    Make the swap? Into what? A boat? A Motorcycle? A Mini-van? I would suggest asking more specific questions...
  3. schmuck
    schmuck New Member
    :ph34r:Eh im no wise ass but the title states a DA trans, Im hear for help no to piss some one off. Ill make my questions more solid.
    Where can I find a Bseries Cable trans and what DO I have to do to replace my old one.
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    auto or stick ?.....and all yo have to do is unbolt the old and bolt back on the new
  5. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    R&R (remove and replace), you are going to have to pull your axles, halfshaft, alternator, and probably your right tie rod. While you are at it you might as well resurface your flywheel or get a lightened one and get a nice new clutch also.
  6. 91_civic_si
    Wasilla, Alaska
    sorry didnt mean alternator, I meant starter.
  7. schmuck
    schmuck New Member
    I dont have to remove the motor ?
  8. AHHVTEC
    Alabama
    no
  9. 91_civic_si
    Wasilla, Alaska
    Not to sound mean, but if you thought you had to pull the motor to change the tranny then you probably shouldnt be even attempting this. Maybe get a professional to do it or a friend who is knowledgable in mechanics.
