dash cam
Discussion in 'Computers, Games, Electronics etc' started by jamesA, Feb 22, 2015.
  1. jamesA
    Friday I got cut off twice in 10 minutes on the same road, I need a dash cam.
    Any recommendations on cameras and storage devices?
  2. chadcharb
    maple valley, Wa
    Didn't @awptickes get a dash cam a while back?
    |Chaz| and awptickes like this.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    in for the read.
  4. jamesA
  5. TurboMirage
  6. jamesA
    Oh hey, I scrolled right over it.
    Dumbass.
    |Chaz| and TurboMirage like this.
  7. E_SolSi
    jamesA likes this.
  8. awptickes
    MD
    I've been running a dash cam every single day since April of 2013. Caught some interesting shit, including a challenge to a cop on I-95 for an "unsafe passing maneuver" that he decided he'd give me a verbal warning after I explained that I had video.
    E's site is spot-on.
    Personally, I run one of these blackstone dash cams, and it records to one of these SDHC cards. Don't buy a cheap card, it's constantly writing, so you'll wind up replacing it in a couple months. Lesson learned. It's hardwired to the ignition 12v line (same add-a-fuse as my radar detector) with one of these hard-wire things.
    AHHVTEC likes this.
  9. Drake
    Drake Well-Known Member VIP
    That is much cheaper than I expected. I as just talking to my wife about this very subject last week.
  10. GSRCRXsi
    MD
    "G-Sensor Enabled Recording Occurs as Soon as Any Sudden Braking, Impact, Rapid Acceleration or Sharp Cornering Occurs"
    is this selectable? or is this the only way it starts recording?
  11. awptickes
    MD
    No. it always records, it just "flags" the video segment if there's high g-forces. You have to tune the g-force setting, otherwise it'll save every time you hit a pothole or merge on the highway. Once you get it (takes about an hour) you'd good forever. A flagged video segment won't get overwritten until you delete it manually.
    GSRCRXsi likes this.
  12. Briansol
    somehow i have the feeling that if i installed one of these, it would be used against me.
    |Chaz| likes this.
  13. awptickes
    MD
    In Maryland, in order for an officer to view the recorded footage, they have to receive a writ of seizure by a judge. Essentially, a search warrant.
    You'd have a really interesting case, and I'm sure the ACLU would take up your side.
  14. awptickes
    MD
  15. jamesA
    Since I had to go just past Indy today I stopped by Fry's on the way back home and got this.
    came with an 8gb card, and will constantly write over. I'll get a 32gb card later.
    I might install it tomorrow, or this weekend. Not bad for just under $100.
  16. awptickes
    MD
    Hope yours looks better at night than everyone who reviewed them online.
  17. jamesA
    I work during the day, most of my night driving is under 15 minutes at a time. Going to the store, bar, etc.
  18. AHHVTEC
    Alabama
    on this cam is there a way to make it straight record until you want it to stop instead of a loop. in case you want to turn it to your driver window and record the po po
  19. E_SolSi
    with the looping
    generally it records the entire card then "loops" back to the beginning
    and starts recording over the oldest info first, unless that info is flagged either by the G sensor or manually by pressing the flag button, then that section (usually a few minutes before and after the flag) is held and not written over
    as for the average record time... http://dashboardcamerareviews.com/video-recording-time/
    so the cam that pickles has, recording at 15mbps on a 32gb card, should get about 4.25 or so hours of video before it needs to "loop"
  20. |Chaz|
    |Chaz| Well-Known Member VIP
    My thoughts too Brian...
