dead midrange power
Discussion in 'Civic and del Sol - EG and EK' started by sernmd, Dec 28, 2008.
  1. sernmd
    sernmd New Member
    i did a manual coversion on my sol (d16z6) then i bought a chiped ecu cars been running fine but it seems like between 3500 and 5000 r's its got no balls then when it hits vtec it rips and i know its not sapose to do that it should be smooth so is it the chip or should i be looking at other stuff??? its not the plugs wires cap or rotor all a month old.
  2. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    if i had to guess, i would say its the chipped ecu.... try putting a stock ecu on it. maybe you have a friend with one you can borrow or something...
  3. sernmd
    sernmd New Member
    i switched chips turned up fuel presure and ajusted (retarded) the timing a bit now its the exact opposit...
  4. serrilion
    serrilion In my own little world! VIP
    Vermont
    dunno dude... get a stock brain my thoughts... or take the car to a Dyno shop and have them tune it for you, I would guess to much or to little of a mixture :(
  5. efhondakid
    Akron-Canton, Ohio
    1. Remove junk ECU.
    2. Set timing back to where it should be.
    3. Set fuel pressure back to where it should be.
    4. Enjoy.
  6. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    :ditto: :withstupid: I'd rep you for such simplistic advice, Byron, but I have to spread my kayak around more. :D
    To the OP, EVERYTHING these guys are telling you is correct. I'd repeat what efhondakid already said but there is no need. Do what they suggested and let us know how it goes. Best of luck. :thumbsup:
  7. efhondakid
    Akron-Canton, Ohio
    Luis dont you know by now? That is standard procedure for these types of questions.:D
  8. Luis998
    Orlando, Florida
    It seems like it is more and more nowadays, Byron. :D
  9. rkwoos12
    rkwoos12 New Member
    Kentucky
    check your distributor i had a similar problem and it was dude to one of the sensors going bad in my distributor it was the crank sensor, determines timing for fuel injection of each cylinder and also detects engine rpm so you could have the same problem its worth a try, you can check you sensors by ohming them its the 8p connector un plug it and get a ohm meter and check to make sure each three come out to be some where in between 350 to 700 ohms if its out of that you probably have bad sensor, also check when cold tosee what i read and check when warm.
