Minor problem....
90 crx
driving home from berkeley (about 30min away) almost home ad the engine stops, it still rotates, it just wont continue to move under its own power.
so while coasting i A) try to put it into gear to 'jump start' the engine and get it going and B ) try to turn the ignition to get it to fire again.
no luck so once its stopped i try to start the car, the starter works fine and is strong, but the engine wont start.(turn over)
there is enough oil, and there is a little less than 1/4 tank of fuel left, and there is no leaking coolant/oil (ie nothing 'blew up'), and the battery is fine as well
any ideas on things to check, or what it may be?
90 crx
