del sol gsr swap ecu problems
Discussion in 'ECU's, Electronics, and Tuning' started by delsol93, May 20, 2008.
  1. delsol93
    delsol93 New Member
    So i have a 93 del sol with b18c1. But the ecu is from a 92 integra LS (non-vtec).....this was the ecu in the car when i got it. But i know for a fact i dont have a working vtec. I thought cause of the non vtec ecu. And i dont know if the car has its full potential cause of its ecu also..... I'm just kinda foggy, so any help would be appreciated.
  2. BrutalB83
    Rochester Hills, MI
    Um, ok? Seriously? Have you thought of maybe replacing the LS ECU with a GS-R one?
  3. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    P72 would be the right ECU, just make sure its OBD1. The B18C1 had butterfly valves on the inside of the intake that would open/close under certain conditions.
  4. delsol93
    delsol93 New Member
    Okay, now what about aftermarket? Is there any aftermarket ECU that's a straight swap for the P72, or is it just a chip or attachment?
  5. Z6CRX
    Pittsburgh, PA
    I know of chipped ECU's, complete after market ECU solutions are going to be expensive.
    A P28 is one of the most popular to get chipped, but you can get a lot of OBD1 ECU chipped and wired for Vtec. Chipping and wiring your current one may be the most cost effective solution if you are planning on building your car up.
  6. BrutalB83
    Rochester Hills, MI
    Have you looked into the price of after-market ECUs lately? They're hella expensive. Like I already said earlier, just buy yourself the correct ECU (an OBD1 P72) or look into having a different ECU chipped and programmed to run your motor, as ZCRX mentioned...
