DarkSyde Design
quick question...how would i be able to tell the difference between a b16 block and a b18 block if the block was painted over?
hell.. i dont know for sure..
i figured they did because you need to add those to the LS block to run a vtec head
why dont you just sand down were the code is with some fine sand paper??its worth a shot instead of dicken around...good luck
