distributor install
Discussion in 'General Tech and Maintenance' started by shfaster, Jun 24, 2004.
  1. shfaster
    shfaster Member
    algonquin
    sup everyone. i just got my new distributor from distributor king, and i was wondering if i need to oil the shaft. this is my first time swapping the complete distributor so im not sure whether i should oil the shaft or anything else. thanks
  2. EG18
    EG18 Junior Member
    You shouldn't need to lube it because there should already be lube in the engine, where your going to put the distributor in. and if not just put on of your engine oil on it and plug it in. and make sure your crank is aligned so that the distributor will go in If it's not aligned you need to turn your crank, where the pulley is at. Make sure you turn it counter clockwise.
