1996 lx accord, 93 JDM H22A
well i have it down to 3 wires maybe someone knows them
There was a clip that use to run to the external coil on the accord (the 93 JDM H22 is internal coil) they are, Black/yellow, solid green and solid yellow. ive read that you splice the yellow and black/yellow together...then what, leave them alone or do you run them to the black/yellow wire going into the distributor. if you do run them there then what do you do with the yellow wire that use to be in the same clip as the blue wire for the tach. and the last wire is a solid green wire that use to go to the accord distributor and the h22 distributor does not have this green wire...so what do you do with this green wire. Any help would be greatly appreciated, i havent had my car for six months and these are the last 3 wires i need to figure out...thanks
