Does an erratic idle do any harm?
Discussion in 'General Tech and Maintenance' started by BigBoy, Aug 14, 2005.
  1. BigBoy
    BigBoy Senior Member
    cali 818
    I just did the obd1 conversion and car runs fine, except when im slowing down and let my foot off the brake, the idle goes between 1000-2000 every few seconds. ANy idea what could cause this and is this really a bad thing?
  2. BigBoy
    cali 818
    bump
  3. NoJokE
    NoJokE Senior Member
    It won't hurt anything...
    Have you checked you IACV? Are you getting any check engine lights???
  4. Falqon
    Falqon Junior Member
    That happens when the ECU is struggling because there is too much air entering your engine. Probably a vacuum leak somewhere. Does it do it all the time? When the engine is hot? Cold?
  5. BigBoy
    cali 818
    nevermind i fixed it. The idle adjustment screw was loose. Idles nicely now. Thanks!!
