does check engine light affect HP?
Discussion in 'Integra' started by TeggyMan, May 31, 2009.
  1. TeggyMan
    TeggyMan New Member
    Waterbury, CT
    even for like a sensor if the light is on does it rob ur HP ..someone has told me so just checking?? if anyone can help
  2. George777
    George777 ^^ Likes Bewbies
    With your mom
    Depends why the CEL is on. It can be on for a TON of different reasons, and they can each effect a different aspect of how the car runs.
    Your best bet is to fix whatever the CEL says is not working properly. Then you won't have to worry about whether you will/won't be running right.
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    Most of the time a CEL will cause the ECU to go into "limp mode". It'll run rich and yes, it will rob hp and kill your gas mileage.. Best to fix it right away.
  4. TeggyMan
    TeggyMan New Member
    Waterbury, CT
    wowwwwwww thats explains sooo much.. cuz i bought this car like 2 months ago and the CEL was on when i bought it and the guy i bought it from told me it was just because of a sensor or something cuz he did a b18c swap on it and thers no A/C so maybe i thought that was why it was on but i did start to notice how i thought it was runin rich and it bogs down alot in first and i have noticed gas mileage not as good.. but how do i find out wat the CEL is on for?
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    Pull up the carpet in the passenger foot area, the ECU is behind there. There is a red LED in the little window in the center of the ECU cover. Start the car and count the number of flashes. There may be more than one code, so it could flash 2 times, then flash 15 times, repeat forever.. Count the flashes in each set and post up the numbers.
  6. TeggyMan
    TeggyMan New Member
    Waterbury, CT
    just did so.. there was no ECU just black plactic under the carpet?? hope u wernt messin with me lol
  7. TeggyMan
    TeggyMan New Member
    Waterbury, CT
    or is it behind the plastic?
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
    My bad man, I have CRX on the brain.
    Its under the Passenger kick panel, to the right and below the glove box.. Plastic guard thingamagigger.
    But it doesn't have the handy dandy LED like the CRX does. Ok. Lets start churning out some helpful information, shall we?
  9. TeggyMan
    TeggyMan New Member
    Waterbury, CT
    man i appreciate ur help and everything but i just toor that carpet up and didnt see any flashing red lights.. the car was on and i looked in the whole area didnt see anything that looks like an ecu?? is it off to teh left towars the radio?
  10. TeggyMan
    TeggyMan New Member
    Waterbury, CT
    do i have to unscrew anything to get to it?
  11. phyregod
    phyregod !!YTINASNI
    Central Texas
    no, put your carpet back. Read the above quoted section.
  12. TeggyMan
    TeggyMan New Member
    Waterbury, CT
    yeahh i just found the ecu lol its to the right like u jusr said behind the plactic peice but like u said thers no red LED so ill readf ur quoted thing now
  13. TeggyMan
    TeggyMan New Member
    Waterbury, CT
    ok i did everything im reading the code..it does flash multiple times but it just seems to do the ssame thing evberfytime... just one long flash over and over.. cant come up with a code?
  14. BrutalB83
    Rochester Hills, MI
    Did you read up on how to interpret the codes? If it's just one long flash, then I'd say it's probably code # 10, the IAT sensor. Either that, or it's your primary O2 sensor...
