you mean on the turbo? What kind of turbo is it?
Look at the turbo how it will be mounted on your engine. The oil line from your oil pressure sending unit (or wherever your oil is coming from) needs to go into the top hole on your turbo. The drain line going to your oil pan comes out the bottom, opposite the hole you put the oil-in in to. If there are 2 more holes going front to back on your turbo they are for coolant. Hook them up in any direction and away you go.
