i know this has been covered 100 times but i went to move C1 to B10 which was empty ok but when i went to move C2 to B12 it had a white /red stripe in it
i was following the instruction and it was suppose to be empty and on the A plug A1 is yellow A3 is yellow A5 is red A7 is red now do i cut these and run wires to the injectors and then to the four wires on the resistor block then A15 to the fifth wire on the resistor block could use all the help i can get
