Dual point to multi point question
Discussion in 'Civic and CRX - EF' started by rollagtsracer, Jan 24, 2007.
  1. rollagtsracer
    rollagtsracer New Member
    murfreesboro, tennessee
    so i have a 89 ef hatch with the d15b2 and i went from dual point injection to multi point injection and it runs funny and sounds like a lawnmower i was wondering i swapped ecu's and did the right wiring the only thing i didnt do was swap the fuel pump could that have anything to do with it?
  2. 801CRX
    801CRX Got Rice?
    UTAH
    Deffinatly!
    Get the crx hf or si fuel pump
  3. rollagtsracer
    thanks this dumbass told me it would be fine with the original cause the ecu would tell the fuel pump to supply more fuel but obviously he was wrong
  4. 801CRX
    801CRX Got Rice?
    UTAH
    The fuel pump only supplies as much as its supposed to. Once you reach the fuel pumps max velocity it wont provide anymore fuel. No matter what the ECU is telling it to do.
  5. rollagtsracer
    i wish i would have found this forum before i did i got the multi point off of a d16 crx i have so im gonna go take the fuel pump off any idea on how long that will take to swap out?
  6. rollagtsracer
    another question... how do you think the d15b2 would handle boost?
  7. rollagtsracer
    does any body know if the crx fuel pump will plug right into the ef hatch it a zc fuel pump
  8. rexaddict
    rexaddict turbo ex
    olympia wa
    it sould take about an hour to take the pump out of the tank
    and an hout to put it in
    just be carfull.patient and do it rite
  9. Reckone
    Reckone EF aholic
    Albany, NY
    The fuel pump wouldn't make a difference, there the same. I have done many mpfi swaps and never had a fuel pump be a problem.
  10. 97hatch
    97hatch ?
    Anderson IN
    check your injector and dizzy wiring its not the fuel pump
    jeez i hate stupid people:angry:
  11. hfrida
    hfrida New Member
    did you kept ur dual port dizzy
  12. Reckone
    Reckone EF aholic
    Albany, NY
    Just a thought, but did you happen to replace the intake gasket for a new one? If you leak coolant into the cylinder it will make it run like a bag of ass.
  13. 97hatch
    97hatch ?
    Anderson IN
    no you cant keep the dualpoint dizzy why are people so stupid and give out false info a dpfi to mpfi swap should only take a brother about 2 hr max and that is doing it right do your research and if you dont know what you are talking about from first hand experience SHUTUP:chair:
