Dumb Question
Discussion in 'Civic and del Sol - EG and EK' started by Codie94, Aug 30, 2008.
  1. Codie94
    Codie94 New Member
    MO
    How would I put my window back into track because everytime i roll it up i have to ull back on the window to make it fit....I cant figure it out i keep trying to fix it but its just not working for me. Man Window
  2. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    You have to take off the inside door panel. There are 2 bolts on the bottoms of the tracks that can be loosened and adjusted. You may need a new rubber track too? I did...
    But that's what I know for powered windows. If you've got manual windows, idk I havn't ever done those.
  3. blacksihatch
    blacksihatch New Member
    theres no dumb question on haondswap.com ....lol
  4. BrutalB83
    Rochester Hills, MI
    I don't think that's true. Judging from your reputation rating I think it's safe to assume you've asked a few...
  5. efhondakid
    Akron-Canton, Ohio
    Manual windows are the same, two 12mm bolts at each end of the glass.;)
  6. blacksihatch
    sticks and stones
  7. newb
    newb phresh VIP
    Backwoods Northwest
    ...may break my bones, but your words will make me go cry to mommy.
  8. BrutalB83
    Rochester Hills, MI
    Did you find yourself a blingin' JDM heat shield for your manifold yet?
  9. blacksihatch
    yup $20 thanks for asking
  10. efhondakid
    Akron-Canton, Ohio
    SO whats the difference between it and a USDM sheild?
  11. daveholiday
    daveholiday Do work
    Pittsburgh, Pennsylvania
    You guys are assholes haha.
  12. George777
    George777 ^^ Likes Bewbies
    With your mom
    I just noticed your sig, Dave. Right on.
  13. daveholiday
    daveholiday Do work
    Haha, I died laughing when I read it because it's all too true lol.
  14. craiger
    craiger New Member
    Austin, Texas
    Is your window problem on the 94 civic? Is it manual or electric? Is it a 2 or 4 door? I have noticed on the 2 door especially that when the door gets slammed alot that the window either comes off the tracks or the tracks get bent/twisted over time. What I have done is taken out the entire track system and bent it back. This is difficult but it has worked for me. I have also seen the rubber that goes inside the tracks get worn the wrong way and need to be replaced. Let me know. Good Luck.
