dx/si tranny 91
Discussion in 'Civic and CRX - EF' started by RcRacing72, Mar 13, 2007.
  1. RcRacing72
    RcRacing72 Junior Member
    Wisconsin
    Ive heard that the only difference between the dx and si tranny in 89-91 is 5th gear.
    Is it a longer or shorter gear?
    Im looking for the reason why 5th gear is different?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yea the si tranny will be a little bit shorter geared, but not enough to worrie about it
  3. RcRacing72
    Wisconsin
    thank you!
    Getting new tranny in my 91 hatch, (sohc) Debating on weather to pick up a clutch and flywheel.
  4. AHHVTEC
    Alabama
    just make sure its a 5spd tranny
  5. RcRacing72
    Wisconsin
    i was looking at a flywheel and clutch from LSD.
    Not too much for plans for the car, but ya was thinking since it was out, why not. Gonna wait till the tranny i got is pulled, cause i dont know if the guy did anything too it.
    I figured thats all i can do with the tranny, probably get a cheap short shifter too.
    dunno what i'd do to engine since its sohc, rather have a zc dohc
    but if u got some suggestions, feel free to shoot.
    LSD Motorsports: LSD RaceWheel Flywheel
    LSD Motorsports: LSD MILD PP/6 PUCK SPRUNG
  6. RcRacing72
    Wisconsin
    Im looking at two options, just drop the tranny with clutch and flywheel.Run me about 850
    Or
    Order a zc dohc , clutch and flywheel, water pump. Run me about 2k
    Edit: Thats with labor.
  7. AHHVTEC
    Alabama
    thats about a 1000 bucks to much you can get a b16a sir 2 for 2 grand with a tranny
  8. RcRacing72
    Wisconsin
    Thats with labor, sorry I didn't really specify that.
  9. AHHVTEC
    Alabama
    just do it your self its very easy
  10. RcRacing72
    Wisconsin
    I would but i have no shop to do it at :(
  11. AHHVTEC
    Alabama
    i did my first swap in the gravel driveway,thats all i had and i rented a cherry picker to get the motor out, and it was a h22a in a civic.
  12. RcRacing72
    Wisconsin
    ya doing it myself would save me like 750.
    (nice specs blanco)
    we'll see, idk none of my buddies seem up to it, letting me use there place.
  13. RcRacing72
    Wisconsin
    lol
    ya i think im gonna just have a tranny put in with a flywheel and clutch.
    save me a lot of money, car will be fast enough for me, got alot of compression. i can go down hills in 5th and the car slows down :huh:
    but i would drop a zc dohc in my bandit, blanco, run that with a light ass flywheel and clutch, and i will be set. I'd be doing that swap with my dad, since im not gonna dedicate myself to racing till i have a shop.
    blanco u should send me pics of ur car!
  14. RcRacing72
    Wisconsin
    is there a way to tell the difference of a dx and si tranny (91) ? just by looking at em' (ex. serial numbers?)
  15. thompsonrx7
    thompsonrx7 Banned
    basically I always got it from the gearing how it is laid out.... depending on what i am doing with it is how i chose the transmission i used.
  16. jlicrx
    jlicrx Senior Member
    Colorado Springs
    not any positive way to tell just by looking at them
  17. thompsonrx7
    thompsonrx7 Banned
    Yea you kind of got to install them and see the difference in the gearing, i suppose you could take it apart and maybe tell the difference...lol
  18. RcRacing72
    Wisconsin
    i was told there was a difference but they guy couldn't remember, so i figured id ask.
    I would of done something with the serial numbers, like they do with the vin's
  19. jlicrx
    Colorado Springs
  20. RcRacing72
    Wisconsin
    wow thats a procedure, but it helps thanks.
