Ecu For B18b Swap
Discussion in 'ECU's, Electronics, and Tuning' started by Sirhc2013, Jan 12, 2003.
  1. Sirhc2013
    Sirhc2013 Member
    Ocean City NJ
    I am looking to swap a 96+ LS into my EG Hatch. What
    year ECU should I use b/c these engines are obd 2 is there a better Ecu year or will all Obd 1 do the trick.
    Will I need and Obd 2 --> 1 Harness.
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Sorry, I don't know my Civic chassis codes. I assume the EG is OBD1. If so then an OBD1 ECU will work and I just happen to have one for sale.
  3. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    id get the dizzy, injectors, IM/tb,..... etc and have it all obd1 and use a p74 ecu
  4. chet
    chet Senior Member
    st petersburg, florida
    it depends on your setup, if you are using an obd1 engine harness, obd1 distributor, etc, then go with an obd1 ecu.
  5. SolReaver
    SolReaver Senior Member
    Buy lsvtec's ecu that he has for sale. Thats all you need- the integra harness will plug into your civic one at the shock tower connection. The ecu will plug into the stock harness.
