Ecu Pin Jumping?
Discussion in 'ECU's, Electronics, and Tuning' started by sprfreek, Feb 15, 2003.
  1. sprfreek
    sprfreek Junior Member
    Ok i've been searching for a while now and haven't found anything. Ok what my question is: How does this work now with using a paper clip to jump the ECU to set the ignition timing yourself with the distributor? where is it jumped? and what is the exact way of doing it? i have some idea but i'm not sure. This is for a 95 civic HB with a fully rebuilt 94 b18b1
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    I am not sure if it is different for your ECU, but for My OBD1 P72 and for the OBD1 PR4 I was running before I did not have to jumper anything to change the timing.
  3. sprfreek
    ok asked a round to some peopel that signed on ... yes there is a way to do it... and if your doing it the way i'm thinking .. the ECU is just resetting itself becasue ti thinks something is wrong
    http://jdmfan.com/technical/performance/ad...advancedtiming/
    there's a link that shows detailed instrustions and lets peopel know that the markings on the crank mean ....
    being the domestic guy in the import world get's confusing
  4. lsvtec
    I have never had the ECU reset the timing. If I set it to 17 it is still at 17 when I come back two weeks later.
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Sounds like a load of crap,if you advance via the distributor it shouldn't auto retard it.
  6. sprfreek
    posted from xsolidcellx (on honda-tech)
    he said it the best .. i knew it did this ... i just didn't know the exact way on the pin jumping .. and no it's not a load of BS ... do some homework before you ranting
  7. xj0hnx
    C.C.TX.
    No one is ranting...read the first four words of the post "Don't have to but..." so chill out. ;)
  8. sprfreek
    damn this is one chilled thread.... and hey i am chiulled out I'M IN BUFFALO!!!!!! it's -3
  9. xj0hnx
    C.C.TX.
    Damn,that is cold. :eek:
  10. lsvtec
    Mmmmm 60 degrees here.
    So which plug do they claim you have to jump?
  11. xj0hnx
    C.C.TX.
    First you suck for having 60 degree weather :lol:
    This is the plug:
    the service connector.
  12. lsvtec
    60 was this morning, it's more like 65 or 70 now. :)
    Thanks, I'll try it next time I set my timing and see if it makes a difference.
  13. sprfreek
    did make a diffrence for me .. definatley works
