Edelbrock 65mm throttle body
Discussion in 'Engine Building' started by Teambypass, Jul 1, 2004.
  1. Teambypass
    Teambypass Senior Member
    I just purchased an edelbrock 65mm throttle body but the throttle body seem hard to pull. I reved the engine up to 8k RPM and the throttle plate only open 25% not even 3/4. the spring coils on the throttle body are really tight and I assumed this is what cause it. I unlock the nut and loosen the spring coils on the throttle and same thing happen,the plate wont open fully. Any help or suggestion?
  2. Johnnylawless
    Johnnylawless Senior Member
    well I am waiting for mine to come in, but is the valve hitting the inside of the manifold?
  3. TANGFUNG
    TANGFUNG Junior Member
    try adjusting the throttle cable, that should do the trick.
  4. B16
    B16 Super Moderator VIP
    yay area, CA
    is it physically not openening 100%? or is the percentage you read on your VAFC? could be the TPS is not calibrated?
  5. Teambypass
    as i mention on the post, I reved the engine up to 8000 RPM and the throttle plate only tilted a little bit, approximately 25%. When I manually open the throttle body, there is a scraching sound, which I assume to be the springs, but I was wrong, it was the throttle plate that make the noise. there is no visible scrach on the inside of the throttle body, but the steam that hold the throttle plate with two tiny screws seem to be harder to pull by the cable than the stock. I sent the throttle back and hopefully they exchange for a new one or refund me back. thanks for the helps!
  6. b18delsol
    b18delsol Member
    i have the same problem, hope u have warrantee on that thing
