EF rotors
mattus72
Member
the rotors on my 90' civic hatch are warped and im going to pull them off and put on the new ones i just bought.i havent had a chance to pull the wheel off and look at what im going to have to do. i pretty much just wanted to know if i have to pull off that axle nut in order to get off the rotors? and what is the quickest and most efficient way of putting them on?
no you donot have to remove axle nut
you will need a impact driver to remove screws (dont try to remove them with out one its a 99.99% chance that you will strip them out then you have to drill them)
you just have to remove the wheel and caliper push in the caliaper to allow for the extra width on the rotor and your done
enjoy geting dirty and good luck
