engine codes
Discussion in 'Integra' started by hazzardboy95, Dec 6, 2006.
  1. hazzardboy95
    hazzardboy95 Hon-daaaa
    Pasadena, Md
    can anyone answer my question, what is the engine code for a integra lsvtec:D
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well its ither a b18a or b18b
  3. hazzardboy95
    Pasadena, Md
    The B18b1 Is What I Have Now, So Your Saying The Lsvtec Is The B18a1
  4. eg6sir
    ls/vtec is made up of 2 different motors
    you have alot to learn
    a b18a or b block mated with a B16, GSR or type r VTEC head... hence LS/VTEC..
  5. AHHVTEC
    Alabama
    well you kinda answerd yourself there if its a b18b1 then thats what you have
  6. eg6sir
    this kid doesnt know his asshole from his face..
  7. hazzardboy95
    Pasadena, Md
    no what i have now is a b18b1 wich is the ls non-vtec, im looking for the engine code to the lsvtec
  8. AHHVTEC
    Alabama
    there is no such thing the ls vtec is a ls block b18a or b18b with a vtec head put on it
  9. hazzardboy95
    Pasadena, Md
    i really dont mean to ask stupid questions so i want to apoligize, im new to the scene and i sometimes think i know more than i really do. i figured that the lsvtech motor was one all its own, not pieced together. im sorry for my confusion. if you could help me out i would appreciate it, i want to learn and not look retarded
  10. eg6sir
    i told you right here what it was
  11. hazzardboy95
    Pasadena, Md
  12. myah
    myah Neu Impact Performance
    ks
    shit if you wanting to do a ls vtec set up i would go with a gsr head their pimp on that combo strong too i would turbo that bitch right then and their
  13. hazzardboy95
    Pasadena, Md
    i was thinking of keeping it n/a but when i changed the head i was gonna try to find a type r head since they can rev higher and withstand higher compression.
  14. 91integra
    91integra New Member
    Connecticut
    no offese, but considering that you didnt even really know what an lsvtec was, i would strongly consider either buying an lsvtec already built and having it professionaly installed, or buy all the parts you need and having it professionally built, theres A LOT more to it then just putting a vtec head on it and calling it a day... but thats just my $.02...
  15. eg6sir
    ^^exactly what i was thinking
  16. DAHATCH
    DAHATCH New Member
    you have alot of research to do
    I dont know as much as most people on here, but getting the type-r head is just a waste of money. The head would be able to rev very high but the bottom end wont take that abuse so you might aswell just get the gsr head and build the block and the head. thats my $.02
  17. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
  18. myah
    ks
    ok on you tube this guy has a yellow ls/vtec set up seems pretty fast he's got itr(integra type r) pistons and stage 2 skunk 2 cam shafts with a b16 head and that seem like a good set up cause the b16 give you better air flow than the gsr or b18c head i would consider that if you buy the part you could have someone install them for you it's not that hard but like someone said you didn't know what it was but your learning just take that into advice
  19. MikeBergy
    Central Coast, CALI
    Just know that airflow differences in the pr3 (b16,itr) and p72 (gsr) are very small. Most people that want to make good power and plan on modifying their heads, i.e. port/polish/chamber work, go with the gsr head, as it is a much better casting, and the combustion chambers yield a slightly higher combustion ratio, good for a bit of power. The b16 is more popular because it is cheaper, and more readily available, and a factory type r intake manifold can be used on it, making it more cheap. The gsr head is definitely the better head.
  20. myah
    ks
    true but the b16 head has better air flow making your car higher compression it is cheaper but i think you will get better power out of the b16 head rather than the gsr head
