GSRLude:
I have a question about the MAP sensor on my JDM H22a. I'm installing this swap into a `99 Integra and I was wondering where I should plug the MAP sensor into...can't seem to figure out where it should go. Thanks for any help.
VTECsqznN2O:
one end connects to the ecu and the other to the map sensor...then theres a vacumm hose that comes to the manifold under the mapsensor. on the ecu side the map sensor wires should already be tapped into the 32 prong connector.
