BoostedH22
i have a 95 civic ex with an h22 swap gt4088 turbo, rc1200 cc injectors, mainly pistons, eagle rods, tail wastegate, hks bov, greedy fmic, hondata s300, walbro 255 fuel pump, fuel pressure regulater, fuel rail and all the goodys. it has been runing fine untill about a week ago when it started spiting and sputering. i thought it was just water in the gas so i runn all the gas out and got gas from a different station(octane 93). it was still sputering so i went and got a new fuel filter and a can of seafoam. i put the whole can of seafoam in at the parts store and went home and changed the fuel filter. it seemed to clear up until the next morning when i left for work and it only got worse. it will only get to about 2000 to 2500 rpms and it just cuts out like i have let of the gas it will bog down to about 1000 rpms and then it will start pulling again till 2500 and then it bogs again. the cars needs to be retuned due to the new turbo and biger injectors that was put in it when i got it but it has alway run pretty good besides it loading up every once in a while. i downloaded the s300 software and pluged it into the car but didnt realy understand anything i was seeing but the basic stuff ( i have always played with n/a foxbody mustangs). i checked the error code tab that was on the software while pluged into the car and it didnt pull anything up. has anyone ever had this problem or could some expain to me how to better use the s300 software. any advice will help. thanks
