I have just purchased a B18b1 and am goin to start rebuilding the block on an engine stand, however i am not sure what bolts to use to mount the engine to the stand and what holes to use. I know most of the time you just use the trans bolts but the stand i have wont allow it to happen like that. It has a four inch hole for the bolts to go thru first before it goes into the block and pictured here Engine stand (top left 1000 pound capacity)
What size bolts should I use on the block and what holes to use?
thanks
thanks
