Engine trouble
Check to see if your injectors are running low on oil or-
-J/K Check the smallest things first it almost always is something small good luck.
injectors are fee to check just pull of the fuel rain and swap the injector to the next cyl..(injector not wiring) and if that cyl dose it and the other is fine then the injector is the problem...(this only works on mpfi cars)...i had the same problem yesterday....
