f20b ecu question
Discussion in 'Accord' started by calmfornow, Jan 11, 2008.
  1. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    im lookin at this 97 accord and it has the DOHC F20b but i dont know what kind of car i can pull the ECU out of it, cuz it needs a new one. does any one know what car it will work with.....its 5 spd....i also dont know the original engine
  2. ninjafoo
    ninjafoo New Member
    tucson,AZ
    use the p28 ecu i know someone who has the f20b and this is the ecu they use
  3. BrutalB83
    Rochester Hills, MI
    I'm sure your friend's P28 is chipped and tuned to run the F20B. A completely stock P28 won't necessarily run it correctly.
  4. calmfornow
    Zionsville, pa
    would it run if i put the stock ecu in there...i need a stock ecu that make it run correct, cuz we started it and it does run, but it spits and sputters. it is drivable but i was just wonderin what kind of stock ecu i can throw in it so it run good
  5. BrutalB83
    Rochester Hills, MI
    Is the engine VTEC or non-VTEC?
  6. Uncle Buck
    Uncle Buck JDMDecals.com guru
    Spearfish, South Dakota
    F20b is a non-vtec motor.....
    i dont see why a P12 ecu wouldnt work....its out of the F22a1, only issue i see is that the F20 is a DOHC so perhaps cam sensors being differnt??? idk
  7. BrutalB83
    Rochester Hills, MI
    Uh...no, not always. There's a single-cam version and a dual-cam version, and both of them are available with VTEC. The dual-cam F20B is basically a 2 liter version of the H22.
  8. calmfornow
    Zionsville, pa
    yea it is the F20B vtec version of it......and i see numbers for the name of the ecu, where do i find them or how can i get em
  9. calmfornow
    Zionsville, pa
    i was told that the h22 has the same ecu plugs. is that true??? and also if i throw in the h22ecu will it work without reprogramming or no
  10. Uncle Buck
    for some odd reason i was thinking the F22b.... my bad
    the F20b is the same as the H22 but with more aggressive cams......
    so... no clue
  11. ninjafoo
    ninjafoo New Member
    tucson,AZ
    yea my friends ecu has is the p28 with the neptune map
  12. ninjafoo
    ninjafoo New Member
    tucson,AZ
    the f20b can have vtec ive owned one
  13. ninjafoo
    ninjafoo New Member
    tucson,AZ
    and the f20 doesnt just have more aggressive cams. the f20 was made to race in the 2 liter races. its the ths same block as the h22 but just 2L instaed of the 2.2L of the h22. im not sayen the f20b is the h22 im just sayen same blocks diffrent liters
  14. ninjafoo
    ninjafoo New Member
    tucson,AZ
    o my bad brutal i didnt think anyone put that up yet but my avater is the f20b
  15. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    F20B is pretty much a destroked H22A Type-S. Yes, a H22A ECU will work. A P28 with F20B or H22A chip will work too.
  16. bighit699
    bighit699 New Member
    the f20b is an f series cast iron block, with h22 type s head and cam, but there are two different cams put in, one less aggressive (180hp) for the auto, and more aggresive (200hp)for the manual
  17. SlushboxTeggy
    NJ to MA to CA
    Congrats, I was in college the last time someone posted in this thread.
  18. civicious
    civicious FüK-VTEC VIP
    Houston, TX
  19. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    dude ive seen soo many greenhorns posting in dead threads lately lol
  20. Jdtrini
    Jdtrini New Member
    Hi Can a F20B twin cam vtec harness work on an F20B single cam engine 1999 accord
    Facialking88 likes this.
