Quoted post[/post]]
I did a B16A in my 97 Civic and to get the power steering to work, I just got the B16 power steering hose (that was cut) and had it braized onto my stock hose. Worked perfectly. I eliminated my A/C, so can't help with that.
Quoted post[/post]]
no, keep everything you already have in your car. keep the same pump, keep the same hoses, keep the same belts, etc. the only things you'll change are the brackets that bolt the p/s pump and the a/c compressor to the block. use the brackets from a Del Sol DOHC Vtec.
