Flashing code 17
Discussion in 'ECU's, Electronics, and Tuning' started by civicrus, Mar 19, 2006.
  1. civicrus
    civicrus Junior Member
    My ECU is saying I have a bad VSS, but I have replaced it twice and My speedometer still don't work. Do anyone know if I have another bad VSS, or do you guys think its a bad gauge cluster, or something else?
  2. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    check wire continuity?
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    +1
    It sounds more like a bad ground or a wire short.
    My VSS CEL came on, it was full of water, dried it out and cleaned it up, works great.
    PS: It's NOT your cluster, your cluster doesn't care whether or not your VSS is working, and your ECU doesn't ask your cluster whether or not your VSS is working, it checks the sensor.
  4. GSRCIVICTN
    GSRCIVICTN Lost in a sea of rednecks
    Nashville, TN
    +1
    He has answered your question. If you aren't familiar with wiring, have someone look at it for you.
  5. kaoskustoms
    kaoskustoms Senior Member
    casper wyoming man
    if spedo does not work try the guage
  6. GSRCIVICTN
    Nashville, TN
    Cluster has not a thing to do with VSS signal.
  7. kaoskustoms
    casper wyoming man
    will if the cluster is bad it will not take the signal from the vss there for not working
  8. VTECin5th
    Phoenix Az
    I disagree.
    Take your cluster out, drive around the block, come back and plug it in.
    Check for CELs stored using the paperclip.
  9. kaoskustoms
    casper wyoming man
    alright here is a quick tip for most hondas
    when you drive if the spedo does not work and the miles roll you need a guage
    if they both dont you need a vss
  10. GSRCIVICTN
    Nashville, TN
    That pretty much applies to any car or truck with a similar setup. The original question has nothing to do with his speedo working. Read and you will see that this guy keeps getting a VSS code and has repeatedly replaced the sensor. The problem must be in the wiring or (much less likely) the PCM. The cluster will not cause the PCM to see a problem in the VSS circuit. Period.
  11. kaoskustoms
    casper wyoming man
    wont a bad cluster set code? i think it would if it could not recive signal. if the ecu send signal to cluster and cluster is inop wont the ecu see the problem, then set code.
  12. VTECin5th
    Phoenix Az
    No.
    The ECU DOES NOT CHECK THE SIGNAL FROM THE CLUSTER.
    :ph34r: :ph34r:
  13. 95preludesi
    95preludesi Junior Member
    So did you ever find out what was causing the problem? I have the SAME exact problem in my 95 Prelude SI right now. The D4 light blinks and I always throw a code 17 even after I replaced the VSS with a brand new one from Honda.
