Friggin Motor
Discussion in 'HYBRID -> EG-EK / DC' started by mattcalica, Jan 16, 2003.
  1. mattcalica
    mattcalica Senior Member
    k, i got my b16a in my integra, all the wiring is hooked up, i think...but she wont start up...when i turn the ignition she sounds like shes about to go, but then nothing happens...it sounds like theres not enough juice in the battery, but i bought a brand new battery so i have no clue what it is...any help would be appreciated
  2. SolReaver
    SolReaver Senior Member
    Check for spark, fuel, timing, compressoin all connections. What ecu are you running?
  3. farmer_jason
    farmer_jason Senior Member
    florida
    check the ground wire from the battery to the tranny had the same prob sounds like the battery is dead and it wouldnt start the wire broke on the tranny side. def. sounds like a ground prob.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    After checking your 1) grounds 2) fuel 3) fire 4) timing,check it all again.If you have compression on top of all that the engine will fire.Run right,maybe not but fire yes
  5. RFHOMI2U
    RFHOMI2U Senior Member
    I had the same problem in my z6 swap. but I had the firing order wrong on the distributor. just make sure the plugs are in the right spot, and i think (i'm not sure) that the firing order will be 1342. it won't start up if the plugs arn't firing at the right time.
