from d16z6 to b16
Discussion in 'HYBRID -> EG-EK / DC' started by Stam, Apr 13, 2012.
  1. Stam
    Stam New Member
    hi there 1st topic for me!
    i have a d16z6 motor under my hood i want to go from this engine to a b series engine
    maybe a b16 (vti?)(im from greece 1 liter of petrol here has 1,85euro)
    can i keep parts from the d16 like the driveshaft?or i have to go to a full b16conversion set?
  2. E_SolSi
    no the driveshafts will not work
    you will need a full swap
  3. Stam
    Stam New Member
    the thing is this
    this eg was my oncle car ad he had originaly a b13b2 engine under the hood
    i have bought the esi conversion for my vehicle (i choose d16z6 instead of b series motor to save some bucks) but now i want to go to b series
    here are some price tags from a dealer here in greece
    full conversions
    Μετατροπές (μοτέρ-πλεξ-εγκεφ-σασμάν):
    S2000 F20C 2.0 >4100€
    Β16Α2 1.6 vti 160hp >1500€
    B16A JDM 170hp >1600€
    Β16Β civic type r EK9 185hp >2900€
    B18C4 1.8 vti170hp με μπλοκέ >1500€
    B18C/C6 Integra type r DC2 >2800€
    K20A Integra type r DC5 >4500€
    Κ20Α2 civic type r 2.0 EP3 >2800€
    K20Z4 Civic type r FN2 >3200€
    H22A7 215hp Accord type r 1999 > 2300€
    what do you guys think is better for me? the prices include engine.ecu,transmission,wire harness nothing more
    sorry for mistakes that occured
  4. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    You'll also need the shift linkage, at least the rear transmission mount (connects near firewall), and axles
    If and only if your current engine harness is working perfect with the D16Z6 swap.....you can use it for B-series motor. You'll just need to extend a few lines to meet the sensors and such on the B-series motor.
    B16 transmission's 5th gear is kind of short. It helps with the low torque of the small displacement engine. This means high rpm cruising on the highway. So commuting will suck up more gas than a B18B or B18C (GSR) 5th gear.
    My favorite B-swap is a GSR B18C. It will be fast and still get 12kpl (32-34mpg) with a responsible foot (not drag racing everywhere)
  5. Stam
    Stam New Member
    what do you think for the B18C4 1.8 vti170hp? its at the same price as the b16
  6. CAFROG
    NOR-CAL
    More power and a better 5th gear for highways.
    Only thing is you will need to run wiring for the IAB's and Knock Sensor. These wires are ran from the sensors to the ECU. The B16 doesn't have IAB's but it still needs a knock sensor wired up.
    Those two sensors are not a part of your D16Z6 so they must be added unless you run a chipped ECU that has them deleted I the programming.
    Stay with a OBD1 swap.....since you have a OBD1 set up right now.
  7. Stam
    Stam New Member
    yes my d16z6 swap is perfect-complete
    if i do the swap to go b series i must find a vti conversion
    160 hp b16a2()its going to be cheaper right?) but its gonna be complete with engine driveshafts altenator axles.engine mounts+++++etc i alredy have a p28 ecu do i keep it or i can sell it?
    i must found and someone to buy my d16z6 conversion to gain some money back first of all
    today i got my car with my new paint on it now its white with black hood !how much badass?
    my engine bay is still red thoe but when im going to swap in to b series im gonna paint the engine bay white or a different badass color
  8. CAFROG
    NOR-CAL
    Here in the USA....a B16A2 is OBD2 so be careful. It will work but takes more work. You wand a SiR II OBD1 B16A
    You also want a OBD1 P30 ECU for a B16A. Sell the old motor, trans, axles, shift linkage and ECU (it will not work a b-series motor without a chip)
  9. Stam
    Stam New Member
    yes i will sell the d16z6 conversion i bought it last september for 1200euros i will sell it about the same price +/-
    the whole d16z6 conversion is in perfect condition,all belts are new,new water pump,and some other minor things
    here in my country i heard alot about the hasport engine mounts are they so much better than the stock oem?
  10. ftp6911
    ftp6911 New Member
    d16z6 to b18b1
    So im doing a swap i got everything i need but im not sure what axles to use will 94+ integra axles fit or do i have to combo if so what's the right combo
  11. Stam
    Stam New Member
    what swap exactly?
  12. CAFROG
    NOR-CAL
    OEM is fine. You can even use 3M windshield welding compound. It's black goo that hardens to make OEM mounts a little stronger. But I've ran OEM mounts with bswaps for over 12 years daily with no issues. hasports are nice because they are strong and hold the motor/trans when there's a heavy load but they also are stiff. You'll feel It rattle the car a lot more when you are idling.
  13. Stam
    Stam New Member
    i havent decide to go b16a3 or b18c4
    but for now im going to collect money
    and we wil see...
    something more i beliecve that you can find obd1 to obd2 conversion harmness is that right/possible?
  14. CAFROG
    NOR-CAL
    Man...tons of possibilities and ways to make anything work. But.....like I told you...you SHOULD stay OBD1. Or...read a lot more (hundreds of threads) and start learning.
    Anything you are reading About a conversion is for OBD2 chassis trying to run an OBD1 ECU.
    You are already OBD1 with the D16Z6 so why are you thinking about stuff I have tried to stray you away from? Is your selection that bad?
  15. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    There's really no choice there, B18C4 ...do it.
  16. Stam
    Stam New Member
    its the same money... and b18c4 comes with torqsen and not lsd!
    can you guys give me a price list for the above
    how much my mechanic +/- going to charge me?
    how much+/- for the engine mounts?
    and the for the electrics?
    also for the axles i just have bought a set of four 4x100 17inch rihms
    with b18c4 i can keep my new rihms pr i must change axles and rihms?
  17. xj0hnx
    C.C.TX.
    Mechanic shouldn't charge more than $300ish, give or take, mount you will use a mix of the B18/16 and the ones you have now, the axles will be fine, the B series axles fit in your D series cars hubs.
  18. Stam
    Stam New Member
    wow now thath i know about the axles im relieved
    thanks a lot my friend
  19. Jpc1320
    Jpc1320 New Member
    so I have a 94 Del so si witch is a d16z6 I bought a engine complet b16 sir obd1 with 30k miles my question is the harness on the b16 is cut I wanted to kno if I can use the same d series obd1 on the b16a obd1 I just bought. Will it just slap on or do I need to modify some sensors ?
  20. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    .... superrrrr old and dead thread.... and kid use your eyes and brain, look at the connectors visually and that will give you what your looking for
