lsvtec
GNU/Linux Evangelist
I am looking into selling my engine. I am willing to take cash or an 93-95 B18A/B longblock, flywheel, and ECU + cash. I have not really set a price yet I am just looking into this at the moment. Here is a list of what is included:
Everything from throttle body to exhaust manifold and from valve cover to oil pan including a 9 LBS flywheel. This includes a 94 GSR ECU. The engine is using OBD1 electronics.
Head:
89 B16A head
Skunk2 IM
Skunk2 Valves, valve springs, and retainers
2001 spec ITR cams (same grind as the CTR)
DC Sports 4-2-1 2 peice ceramic header
Bronze valve guides
Block:
93 B18A1 block
81.5mm bore
Endyn 11.5:1 rollerwave pistons
Ealge rods
GSR timing belt and water pump
ITR oil pump
inline4.com LSVTEC oil line.
Clutchmasters 9 LBS aluminum flywheel
Currently running an ITR clutch that has 20K on it, that could go with the engnie if you wanted it.
The engine has 12K miles on it since I built it Jan 03. It is stilling running strong. I have reciepts for everything that was replaced (all bearings/seals/rings) except for the rods, but they were purchased from pissedoffsol and he can vouch that they had 0 miles on them before I used them. I am looking at selling my Integra when I get out of school and I don't want to try and sell it with this engine to some dumb kid that will toast it. I would like to see it go to a good home. Let me know if anyone is interested.
Head:
89 B16A head
Skunk2 IM
Bronze valve guides
Block:
93 B18A1 block
81.5mm bore
Ealge rods
ITR oil pump
