I want to turbo charge my ZC (1.6L) after it is running right
I have a t25 turbo from a 2.3 liter SAAB 9000 which i heard is perfect for my engine
I can get a Manifold (which is better LOG or equal lengths)
timing retarded by MSD
check valves on MAP
HOW TO ENRICH FUEL??
I am trying to spend as little money as possible (example NO Rechipped ECu)
i have 1.8 liter injectors if needed
Projected LBs of boost is 10 MAX
i guess my choices are
FMU (FUEL adj. by lbs of boost)
Auxillary injectors?
WHICH ONE IS THE BEST FOR THE MONEY and Work the BEst for Enriching my fuel only in boost condition????
check valves on MAP
