Is it worth getting your injectors cleaned or should I just buy a new set? If I do get them cleaned, does anybody know where I can get em cleaned in the Torrance, Ca area?
I forgot the name of the site and I am too lazy to check, but if you search honda-tech you should be able to find it. Tha name is on the tip of my tounge...
It's like $11 per injector to have them cleaned and balanced.
You can use seafoam to clean them. You just add the recommended amount to the fuel tank and off you go. Just make sure you get the right one for your specific application.
They are found at most automotive supply stores like AutoZone and such.
Originally posted by BLKCIVICPN0I@Dec 18 2004, 12:37 AM Is it worth getting your injectors cleaned or should I just buy a new set? If I do get them cleaned, does anybody know where I can get em cleaned in the Torrance, Ca area?
