Function & Form vs. Skunk2
Discussion in 'Wheels / Suspension / Tires / Brakes' started by GlassHeadlights, Apr 5, 2009.
  1. GlassHeadlights
    Calgary, AB
  2. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    ground control coilovers w/ konis is supposed the best bang for the buck setup that you could get in your price range. i have always liked the kyb adjustable shocks too.
  3. GlassHeadlights
    Calgary, AB
    I've heard that too. Isn't it like Koni Yellows or something?
  4. GlassHeadlights
    Calgary, AB
  5. eg6sir
    tokico hps are basically a stock replacement
    Koni Yellow/GC combo FTW!
  6. TurboMirage
    since you are poor and cant afford a decent entry level coilover i recommend k-sports... bottom of the barrel only for the best.
  7. eg6sir
    very true.. i looked up the price of the koni/gc and its out of his budget
  8. GlassHeadlights
    Calgary, AB
    Thank you guys for your support.
    I am pretty poor, making $500 a month working at my local garage.
    I do have about $1100 on the bank right now though.
    I may even just buy some ground controls and put them on my stock struts.
  9. GlassHeadlights
    Calgary, AB
    Where could I find K-Sports? I couldn't fimd them on eBay.
    If I wasn't so cheap what would be the next best set-up? Koni Yellows and Ground Controls?
  10. eg6sir
  11. GlassHeadlights
    Calgary, AB
    If I were to just get Ground Controls on my stock struts would it still be an ok ride?
  12. eg6sir
    it would be absolutely terrible .. worst thing you could do.. if anything you'd wanna use the Konis w/ your stock springs
  13. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    ya brad get this combo. You can lower your car almost as much as you want and still get great handleing and comfort. It is worth the price ( pricey)
  14. GlassHeadlights
    Calgary, AB
  15. built to the max
    built to the max New Member
  16. built to the max
    skunk two coilovers are to bumpy
  17. OGMatt
    vic B.C. Japanada
    Well it all depends if the driver likes it rough or not. lol
  18. GlassHeadlights
    Calgary, AB
  19. efhondakid
    Akron-Canton, Ohio
    My friend had K-sports on his 240, it rode a bit rough but cornered like it was on rails.
  20. eg6sir
    Kyb AGX or Tokico Illuminas w/ Eibach pro-kit or H&R sport.. you wont be disappointed with either choice
    also, i'd stay away from those choices you listed.. the GR-2s and the HPs are basically OE replacement that are good for a .5 inch drop at most.. drop either of those more than 1.5" and they'll be blown eventually
