fuse problems!
Discussion in 'Civic and CRX - EF' started by zanbatou0017, Jul 8, 2008.
  1. zanbatou0017
    zanbatou0017 New Member
    north carolina
    in my 91 civic dx hatchback im having problems with my fuse for the turn signals.
    if i click it on, the fuse blows
    ive tried 3 different brand new ones and all to the same effect.
    this is not only a problem as for turn signals, but that fuse also controls my dash indicators for
    car temp, amount of gas, and speedometer
    i have no idea where to start to fix this and any help is great!!
    thanks in advance
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    there is a short somewhere..im guessing its in the wiring going to the dash lights
  3. zanbatou0017
    north carolina
    how do you sup[osse i start to fix it.
    if there is a short running to the dash wires, then it could be anywhere
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    start checking wires
  5. 91crxhf
    91crxhf New Member
    Oxford, Al
    sounds to me like there is a short to ground, pinched or bare wire, grounding out when you engage the turn signal, probably have to refer to schematics to find out which wire the turn signal switch gets its power from and trace it to the source.......
  6. zanbatou0017
    north carolina
    someone told me it might be a bad flicker and it could be just overloading it
  7. dacheat
    dacheat ..is grounded.
    strongbadia
    yeah. could be the flicker fluid, too. :unsure:
  8. celmore
    celmore New Member
    Springfield, MO
    Dacheat has a very solid point the my car leaks flicker fluid worse then it leaks oil! Sounds like you have a serious problem though and it sucks but first just follow the wires and check anywhere that they come in contact with metal and check for bare wires.. if you dont find anything... dang i feel sorry for ya
  9. dacheat
    strongbadia
    ^x2 -- i mean seriously you could just switch out the bulbs quick and see if it solves your issue but most likely it's wiring. wiring takes time but it's not impossible. just put the work in...
    or go look for some blinker fluid.
