gettin my ECU CHIPPED Vtec Kick In AT?
Discussion in 'Civic and del Sol - EG and EK' started by RedlineHonda67, Aug 2, 2013.
Thread Status:
Not open for further replies.
  1. RedlineHonda67
    RedlineHonda67 New Member
    hey i was wondering when i should get my vtec to kick in i have a 95 honda civic ex with a d16z6 im gettin my ECU chipped and was wondering when i should get the Vtec to kick in any help? thanks for looking
  2. Fernpatch
    Fernpatch Member
    Bellingham,WA
    what mods are you running?
  3. Briansol
    you'll probably make the most power leaving it stock if your car mostly is too. i/h/e don't really matter
  4. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Over nine thousand.
  5. RedlineHonda67
    i have full headers back exhaust ,cold air intake and soon the chip
  6. Fernpatch
    Fernpatch Member
    Bellingham,WA
    I agree with B on this one. Unless you have altered compression, port work, or a hot cam you will not see much of any gains messing with the crossover point.
    You may see some small improvements to economy, drive-ability, and power having the car dyno tuned with the mods you have but an off the shelf generic chip is pretty much a waste.
  7. RedlineHonda67
    another dumb question what is the stock vtec engagement is it 4800 or 5000?
  8. E_SolSi
    ^^ this
  9. RedlineHonda67
    i was gettin a chip and tune by Spoon Sports
  10. E_SolSi
    according to the Helms Manual its 4800
  11. RedlineHonda67
    Thanks Much Appreciated
  12. E_SolSi
    unlikely
    more likely... you were getting a $15 chip off ebay that was a "Spoon Sports chip"
    which means that it is a generic chip that someone threw together that at best is based roughly on the base map that spoon runs in their HIGHLY modded DOHC (usually B series) race cars (hint: Spoon doesnt run generic chip tunes, they tune their cars individually)
    which means that it will be pig ass rich (usually around 11:1afr) and have the ignition and fuel maps all wrong for your SOHC D series engine along with having the VTEC cross over point all wrong for your stock single cam
    you will lose power
    your mpg will blow
    it wont run right
    you will likely blow it up
    stay away from generic chips
    if you want to tune your car get some real tuning software and get it tuned on a dyno
    or get a socketed ECU and get a chip burned specifically for your car...again preferably tuned on a dyno
    street tunes are also acceptable... but either way get a tune that is specific to your car
  13. RedlineHonda67
    thanks for the advice ... looks like im going to be making a trip to columbus later in the month to get dynoed and shit then
  14. RedlineHonda67
    SlowMotion Motorsports
    is where im going to head to
  15. E_SolSi
    really not needed with an intake and exhaust
    are you planning to do a whole lot more to this engine?
    because really if you are staying with a CAI and a cat back exhaust then you are wasting your time and money getting it tuned or even dynoed to tell you the truth
    save your money
    put it in to brakes and suspension
    then maybe some real mods or a swap
    then go get tuned
  16. E_SolSi
    what are your overall goals / intentions for this car?
  17. RedlineHonda67
    im looking to put a turbo on it and maybe run 12 to 1 compression
  18. E_SolSi
    then definitely dont waste your time or money chipping or dynoing shit right now
    you are going to need some serious tuning to pull off a high compression boost build
    definitely not something a "chip" is going to take care of
  19. BrutalB83
    Rochester Hills, MI
    If turbo is your ultimate goal I wouldn't have even bothered with the intake and header...you're not going to need those with the turbo setup...
  20. RedlineHonda67
    no shit i dont have money for the turbo and stuff right now so im dealing with what i have right now i work for my stuff mommy and daddy dont just give me stuff like alot of other people
Thread Status:
