Turbo&Auto
Nick Go FAST!!
Its been pretty cold in PA in the AM, the car is just incredible when its that cold. It reminded me of an idea I read about in a Grand National book and used on my Sube.
SO, I'm going to use that idea from the Subaru and see how it works on a turbo car. The only mods I had at the time was a custom CAI, cat-back, and Underdrive pulley. I was able to pickup .25 in the 1/4 with this idea, AND it only cost like $40.
Here's what it is:
Buy a roll of 1/4" Copper Tubing or 3/8" will work too. Coil it around your CAI or IC pipe just before the Throttle Body. I'll prolly do it down to where my BOV is (pic below for Ex.) Then you unhook your washer res from the pissers and connect it to one side of the tubing. Then drill a hole for a barb in the top of the res and connect that to the other end of the tubing. Now its a complete circuit.
Remove the power connector for the pump and hardwire it to a toggle switch. Lastly, fill it with a lot of Ice and Water. After about 30 seconds the pipe will be freezing cold and you'll see sweat coming off of the tubing
I will get some before and after times on a road by my house. Obviously there's some room for error using a stopwatch, but it should be a noticable difference in time anyway.
I'll post some pics and all later tonight
Here's what it is:
