I made a quick lil how-to of what I did:
Here's the supplies:
20' of 1/4" Copper Tubing, (2) 20' rolls of 3/8" rubber or vinyl hose, 1/4" barb to barb fitting, (4) 3/8" band clamps, roll of 12-16 gauge wire, and a toggle switch. Cost = $45
We start the whole mess by removing the pipe you want to freeze. Uncoil the copper tubing loosely, dont try to straighten it out!! Hold it against the pipe and start winding it around. Take your time here and do your best to get it as tight as possible, both to the pipe and coil to coil.
Remove the washer reservoir filler neck. Drill a 1/4" hole in a place where some hose can be easily plumbed to. Then simply press in the barb fitting.
Connect 1 of the rolls of 3/8" hose to the barb fitting and run it thru a hole in the fender well. Re-install the filler neck.
Cut the washer fluid line that goes to your pissers. Using a 5/16" to 1/4" vacuum fitting, connect the line from the washer pump to the other roll of 3/8" hose.
Route them under the front of the car, this way you keep as much of the engine heat away as possible! Ziptie them up wherever possible so they dont sag and become an eyesore. Make sure you dont tighten the zipties to the point the block off the line!!
Route them up into the engine bay and try to keep them away from hot or moving parts!
Connect the 3/8" hoses to the copper tubing by simply sliding it over the copper tubing and then clamping them tight.
I dont have a pic for this part but lastly you need to make the power connections. Remove the connector from the washer pump and using an ohmeter, check which wire of the 2 is constant ground. Leave it connected and cut the remaining wire! Solder a 12-16 gauge wire to that wire and route it inside the car. Run a 12V wire inside as well if you dont have a distribution block to tap into in the car. Connect them to the toggle switch and you can now turn the pump on and off with the switch.
Here's the finished product:
Tip:
When you get the tubing all coiled around the pipe you want to freeze, tighten a band clamp on one side and tighten the coils to the pipe like you would a nut on a bolt. While holding it tight, tighten a clamp on the other end of the tubing!! This will keep the coils tightly wrapped together AND tight against the pipe!
Some of this is dummied down, but I copied and pasted from another site I'm on and you would be shocked at the questions people ask!
