got a check engine light! 90 siR
Discussion in 'Civic and CRX - EF' started by Schock3, Dec 16, 2008.
  1. Schock3
    Schock3 Junior Member
    got a check engine light on. its been on for a while. i can see the led blinking dont know what its tellin me tho. anyway to bypass the code?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just fix the code, long pulse =10s short pulse = 1s count them
  3. Schock3
  4. eg6sir
  5. eg6sir
    i'm guessing it has something to do with your TPS
  6. Schock3
    7 short ones. TPS sensor?
  7. eg6sir
    throttle position sensor... its on the back of the throttle body.. black thing angled down at 45 degrees
  8. Schock3
    i have been to 3 parts stores and cant find this TPS anywhere!!! any help?
  9. AHHVTEC
    Alabama
    honda, or ebay maybe
  10. Schock3
    just bought a new one for 36.00 Shipped!! hope that is my problem
  11. Schock3
    another question. i have no o2 sensors am i supposed to?
  12. AHHVTEC
    Alabama
  13. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    are you sure something not wrong with your motor
  14. eg6sir
    Honda only sells them with the throttle body
    good deal.. eBay? i know i've seen them on there
    yes.. if you smell gas all the time its because of the missing o2 sensor(s)
  15. Schock3
    na i dont even smell gas all the time tho. that will also throw a code? can i wire up some dummy o2's at the ecu?
  16. eg6sir
    no o2 will throw a code also.. i'd just run one if i were you.. your car will love you forever, so will the air
  17. Schock3
    do you know what wire i should be lookin for off the ecu?? i have 2 wires that dont go to anything. this car has passed emission's and everything.
  18. Schock3
    with one should i run?? on my exhaust the outlet where the o2 screws into is before the cat not after it
