Grounds
Discussion in 'Civic and CRX - EF' started by Speed Box, Nov 26, 2007.
  1. Speed Box
    Speed Box New Member
    What are all the grounds on a 89 civic/crx ?
    1 on engine
    2 on trans by the battery
    I searched and everybody just mentions all the grounds are good etc.
    My problem is I just swapped new motor car won't start and main relay buzzing. I ordered new relay.
    AND there is a wire on the harness thats under the intake mani that looks like an O with wire , its coming from the harness itself I have no clue where it goes. it looks like it fits on the BACK of the starter (front is the battery wire) it could be a ground wire except where does it go?
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    that is the ground for the ECU and most of the sensors - it attaches to the thermostat housing with a bolt
    1 person likes this.
  3. Speed Box
    Yeah thanks for your help!
    There is a small bracket that "fat wire" harness hooks up to. I used that bolt just removed the bracket. It was 10mm and fit perfectly.
