im not positive but iam thinkuing abiout doing a gsr swap into A 91CRXHF If i do it i am going to use a 94-95 gsr and i am going to stick witha b16 cable trans, I will need gsr ecu clutch and flywheel from the b16,obd0 to obd1 harness, and for the mounts , i am going to buy a mount kit but i wanted to know if those are the only mounts i need?, also i have 90-93 integra axles and halfshaft , and wanted to know if those work?Also is there anything else i will need? thanks for the help
Brett
Brett
