gsr into 92 civic VX wiring help
hadeone
im doing a gsr swap in my 92 civic VX.. i bought the car with no engine or engine harness.. now my problem is what engine harness can i use other than the VX.. since i've been trying to get a vx harness for a while now and had no luck.. any information would be appreciated.. please email me at cn718@hotmail.com
thanks
-Cosmin
You can use any 92-95 civic, delsol harness. You are going to have to run the needed wires though. For instance if you get a Si, EX harness you don't have to run the vtec wires, but still have to run the IAB, and knock sensor wires. Other non vtec model harness's require you to run the vtec wires also. I am not sure if the GSR harness will plug right in, I think it does but some stuff needs to be changed around to make it all wire in right.
