Gsr Into 92 Teg
Discussion in 'HYBRID -> EG-EK / DC' started by CrazyAzn, Apr 12, 2003.
  1. CrazyAzn
    CrazyAzn Senior Member
    hi im wondering about swaping a 98 gsr into a 92 teg, and was wondering what i was going to need. is it goin to be pulg n play, or is there goin to be some obd problems, please elaborate on this topic please.
  2. E_SolSi
    you will have to convert your harness to work with the OBD-2 engine .... you will also need to do something about the tranny .... you have a cable tranny the GSR engine has a hydro tranny
  3. SUPERFLY XSI
    SUPERFLY XSI Junior Member
    :ph34r: :ph34r: THE SWAP IS FAIRLY EASY YOU CAN USE YOUR OBD-1 HARNESS ON THE MOTOR AND YOUR OLD DISTRIBUTOR JUST CUT OFF THE MIDDLE LEG TOWARDS THE FRONT OF THE CAR ALSO YOU WILL NEED A 94 95 GSR COMPUTER THIS WILL MAKE YOUR CAR TARE IT UP ON THE STREETS I HAVE THE VTEC PIN OUT IF YOU NEED IT SUPERFLY XSI @AOL.COM
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
  5. sohcslammer
    sohcslammer Senior Member
    Bay Area
