Originally posted by GSRCRXsi@Mar 5 2003, 03:16 PM
i have a b18c1 in my CRX and the ride is pretty good, its not really noticeable unless your at a standstill and turning the wheel. since the engine is heavier, its pretty hard to turn the wheel, but you get used to it. and you are going to have to do a lot of work getting it in since you have to convert to MPFI. then you have to convert to OBD1 (94-95) or OBDII (96+) and run wires for vtec (if you go b18c). my suggestion is get a 94 or 95 to make it lilttle easier. also you need a cable tranny. try and get your hands on a YS1 fron the 92-93 GSR but any b series cable tranny will work. dont get hydro, you need a cable unless you want to convert that too. i suggest using Hasport mounts too, although you need a couple different peices to make it work. hope this helped a little
